9 1/2 inch rims
Just thinkin of gettin new rims and i see some are 9 1/2 inch with an offset of 38 for the rear
Does anyone know if they would foul the arches
Youll be fine, i used to run 9.5" on the rear. And if i remember correctly, 10" on the rear is the most you can go without fouling arches.
nick
i have 9 and a half inch. running 19" and lowerd it is very close to the arch
I dont intend to lower it too many speed bumps round here and i just make it as it is ;)
I think as long as the offset is greater than 35 you will also clear the calipers.
I'm sure it's 35, someone correct me if I'm wrong.
Mine are 35mm offset 9.5 wide and they would catch the wheelarch lip if i lowered it :headvswal :headvswal Had no probs otherwise :D
Looks just the same as mine, but i am just about getting away with it lowered :eek:
