emisions failure on mot possible safc????
- Replies 26
- Views 1.2k
- Created
- Last Reply
jim zx 7 posts
SMW1 2 posts
stenorth 2 posts
EvoluZion3 1 post
my zed failed its ticket on fumes could this be down to the afc set up to run 14psi see my theory is this - its set up to run 14psi but obviously when you rev the engine without load no boost is being used so at 5000rpm theres no boost but its putting in 14psi worth of juice which is big over fueling so would this cause it to fail on fumes ??? advice please if this couldnt be causing what other possibilities should i look at ??? regards jim
