Urgent Help! Car Wont Start!
Please help. My N/A Zed wont start, the engine is trying to start and is turning over but it will not actually start! If some one can give me advice please call me on 07511621307.
What i mean is it does turn over but doesn catch.
take the plug off the ptu and make sure the contacts are clean then re-fit :)
Where is the PTU mate??
the little black finned box on the left (drivers side) cam belt cover
All working now, car had a flooded engine!! AA arrived just as I had fixed the problem!! Thanks to Tommy and Smithy for all your help!
Remove fuelpump fuse, from small fuse box and turn the car over and see if it will start then. If so, put fuse back in.
so what was the prob apart from flooding??
Basically I have a new remote start installed and have been showing it today to family who popped round. As I wasnt driving the car i only kept starting and stopping it and it just flooded engine. No underlying problem thank god!
Went out to the car this morning because remote start didnt work and it took a good 2 second turn of the key and some acceleration to start? Any thoughts? Started it a couple of time since with remote start adn key and works first time!
If it helps temperature was 4 degrees this AM.
I would say stop remote starting the car unless you intend to drive it :D
You're gonna break something !
You probably flooded the engine again.
I never do it now unless it will be driven though? does sound like a flooding tho
By pressing the accelerator you are adding more fuel in, but at the engine cranks it pumps it out also.
If could be a number of things to be honest.
Once it has started does it misfire or run lumpy or is it fine once started ?
It's going to be Fuel, compression or spark. Whether that's electrically controlled or mechanically it's hard to say.
no problems when starting, runs awesome!!! generally no problems starting either!?
I wouldn;t worry about it too much then unless it becomes a frequent occurance.
