Greddy side mount i/cs
Is any body running these?? what do you think ie: performance gains and ease of install??
Just been looking on Smithys/DTA site and thinking of buying them.
Not too bad to install but I've not really had a chance to test them in anger yet. Build quality and price were very good IMO...
Steve :)
'93 UK TT Manual
a little tricky to install and they pretty much fit oem , but had to make a small adjustment to do so. Build quality is very good and as for performance..have no idea lol
I tested at Thor before and after.
However it was Greddy SMIC's, howe rad and electric fan.
I doubt very much that the Howe or electric fan would give me any BHP gains, but the IC's did let me add another 2 psi before det, but then I believe the det was caused by the injectors maxing out rather than the heat sink.
In terms of BHP, it was about 23 BHP gain if I remember correctly. Not a great deal but I bought them as part of a bigger project, one bit at a time so to speak.
Oh forgot to say, when fitting make sure you put the bolts in all holes even if they are not going to be used to attach :slap:
Fitted mine put everything back on and then delevoped a mysterious boost leak. :smw:
I have just fitted some ebay ones and I'm booked back on the dyno on the 9th of jan if I get my dash back in this weekend!
So results should be up around then!
Not sure if i did that, would that cause a boost leak?
If you don't seal off all the holes, the IC will be venting to atmosphere - therefore big boost leak :(
Steve :)
'93 UK TT Manual
I put hand over one end, mouth over other end to check check both of mine built pressure ok lol
Thanks guys looks like a phone call to Danny is in order
Steve :)
Must look into that one as only been boosting to about .5 bar and a code 55. Thanks for that
I doubt very much that the Howe or electric fan would give me any BHP gains...
Electric fan would make quite a difference! No more viscous fan means less drag on the bottom pulley ;) Its not an inconsiderable amount either
