whats gone wrong now
ok was bored today so thought i would try to get cd player worker and whilst i was at it i managed to short something i think
took car for a spin then noticed that indicators were not working so went into tescos car park to investigate took of fuse cover and found diagram is in japanese so thought sod it ill do it after crimbo
car started perfectly drove round the car park towards exit and the car cut out without warning and wont restart although it turns over
called out the aa he checked all the fuses all fine there ,removed a plug thingy to see if spark ,none, checked relays swapped the coil pack one for the sub fan one and she finaly started after clearing the flooding drove car home and the revs would drop at low speed wene pressing throttle wene got car home swithched off and tried to restart she wouldnt
any thoughts anyone
Could it be the PTU on the driver's side cam cover. Mine chucked it on the way home from work after a 5 min drive, wouldnt start, then did start and I drove it for another 10 mins when it stopped again, wouldnt start then did and did the same again until I got home. I messed about with it at home, car chucked it completely, I left it for 2 days and it started like normal first turn of the key. I bought a Series 2 PTU from Courtesy Nissan in USA and its been fine ever since. Doesnt log any fault codes either.
HTH Cheers John
cheers for that mate im hoping its something simple
there was a strong smell of fuel as well as if it was overfueling
Maybee not overfuelling but just working as it thinks it should but you would have no spark. You should do a search of PTU in this forum, I am sure there are plenty other posts relating to similar faults. From previous posts of others the S1 PTU does fail as its probably 18 years old, the newer S2 ones are a lot better.
Cheers John
id bet your indicator fault was a hazard switch button where you may have caught it with your elbow whilst fitting the stereo... wiggle the hazard switch about and see if the indicators work again...
as for the running problem... my first port of call would be the ptu and maf terminals... take em off, give em a clean and reseat. it could just be down to the damp weather. failing that i would try either a known good ptu or a series 2 version...
wow... christmas eve... a skinful and im actually talking sense :hyper:
spot on about the indicators mate took of the hazard switch on top of the pod and they started working again cheers
car started as well ticks over fine until it starts to come up to temp then if you blip the throttle lightly the revs drop then catch but def starts to go rough when getting hotter and thers a smell of fuel
reseat and clean the maf and ptu plugs :) though its possible you could have a boost leak by the sounds of that...
i,ll give that a try ,tried a forum search and it seems to point to a temp sensor as a possible culprit can this also couse these symptons
and oh merry christmas everybody :hyper:
Merry Christmas Tommy, if I remember all the hassle I had with my car happened at Christmas Time, so they must fook up seasonally (or at least mine does)
Cheers John
Cheers John
well thats it then cars not getting its crimbo prezzy then lol
just done an ecu fault code check and its flasshing 13 so looks like a fooked temp sensor anyone have one
if the ecu has been unplugged overnight would this reset it as iv just plugged it in his morning and the fault code is still there although i havent started the car
Resetting the ECU wont change the fault status as its obviously seeing the fault constantly or as an Active fault. If you had an intermittant fault then resetting would clear it until the fault flashed up again. Is there not a resistance check that can be done on the sensor or wiring to the sensor from the ECU?
Cheers John
Cheers John
cheers mate just thought i wouldnt read the fault until the car was started and with the ecu being diconnected from its loom all night i just wondered if it would of cleared its fault codes overnight same as disconnecting the battery
have tryed to clean up connections again so will try it again but i recon the sensor itself is knackered as the connectors didnt look bad
Well that would be my understanding of the ECU logging fault codes as with the ignition on the ECU is running and will be checking all its signals so if it isnt happy it will show that by logging the fault code.
Cheers John
Cheers John
your spot on as usual ,thanks for your help mate
did you have a good christmas
Aye it wasnt too bad, went oot to a local Golf Club for dinner for a change, normally we have a housefull so it was kinda different. Going out to my sis in laws tonight, plus another 2 or 3 nights out planned....kinda hectic.
What about yourself??
Cheers John
Cheers John
nice and quiete for me mate been seperated for a year now so went to see kids in morning then tinkered with car in the afternoon pub in the evening
in fact may be pub again tonight lol
went back to car and the code 13 has gone !!! now showing 55 took car for a spin and fooking hell what a differance ,i must have been in safety mode since i bought the car , came back checked codes again and hey still 55 and no smell of fuel as there usually is ,it must have righted itself ,result ,will still change sensor me thinks :hyper:
Pub sounds a good call. With regards the sensor it might have been the connector and it doesnt take much for the ECU to log a fault. At least its cleared which is good news. I am hoping to get my car converted to manual soon, just need to sell me private plate as I was gonna do it myself but I am thinking of putting it in a garage, but will wait and see.
Cheers John
