p c v valves
throtle hesitation from tickover when engine is cold , could this be faulty p c v valves sticking open . any other suggestions on this problem ? thanks for ANY ADVICE
Mine does that abit..... but hay its like 0 degress out there you cant expect these 17 year old cars to be running perfect from start up.
Thanks For Your Reply , Been A Problem For Some Time , Just Think These Valves Could Be The Cause
Check the temp sensor connector is clean and secure. Check the TPS is set correctly and that base idle is set correctly :)
run thru how to set base idle andy.... theres a little mark on the tps is that supposeto match the one on the body?
thanks for your replies il make this problem clearer, tick over 750 r p m no prob its when i increase revs via throttle [out of gear manual box] hesitation and rev drop of 200/300 r p m sometimes ,cuts out engine .also anyone know of info on p c v valves eg .what problems to expectwhen faulty
