After searching the 'net, I found a couple suppliers had them in stock. First being Torquen - albeit at over ยฃ600 for a pair for either cast iron or aluminium.. Then I found some fully rebuilt aluminium ones (the correct fitting for a TT) at less than half that, which got me thinking. Cast iron vs aluminium....??
Opinions please - good or bad๐
RichardS ·
Hi - i've been told that my car has this - (really) - if so what is it ?
also been told its something like:
independent hydraulic all wheel steering !!!!
Is this just a load of bulll or does it actually exist ?
If so - why does my red HICAS light come on for 5 mins when i drive then go off ? - is this a "level" thing
Would really appreciate any info - thanx
B
:rant:
