ECU indentity numbers
Anyone know what they are??
22
23
36
37
UH
Done a search and I cant find it.
Now im more confused, 8-bit, 16-bit, WTF is all that about???
22
23
36
37
UH
I got 2 ecus for auto tt are both number 23
I think(I know its not good for me so don't flame me) 22 is manual tt
dunno about anything else
the 8 bit were on the earlier cars and the 16bit were on the later cars that conformed to OBCII spec (onboard diagnostics basically)
8 bit and 16 bit refers to the amount of data the ecu's cpu can address at anyone time, and also has some bearing on the total addressable memory available to the cpu.
IIRC someone did once say that having an 8 or a 16bit ecu made no difference to a standard car but it was much harder (if even possible??) to chip a 16bit
90-92 NA's are 8 bit (93 NA's are 8 bit depending on the month)
90-94 TT's are 8 bit
everything above those are 16 bit.
1996 is OBD II
It is possible to socket and chip a 16 bit ECU
Ashspec and JWT does it.
You can tell an 8 bit ecu on the outside by the gold color it has
16 bits are silver.
An 8 bit ECU has a doughter board built in. The 16 bit does not.
Here is an ECU identification chart
http://jimwolftechnology.com/wolfpdf/ECU-ID.PDF
Fault code table
Code Fault
11 CAS in distributor, rpm or crankshaft position sensor
12 Vane/hot-wire AFS
13 CTS
14 Vehicle speed sensor
21 Ignition signal circuit
22 Fuel pump
23 Throttle position sensor - idle
24 Throttle position sensor - full load or neutral/park switch
25 Auxiliary air valve
26 Turbo boost pressure sensor
31 Air conditioning (A/C)
31 No faults detected (non A/C) r
31 ECM - GA16I/CA18DE engines
32 Starter signal
33 Oxygen sensor
34 Knock sensor circuit
34 Throttle position sensor - SR20Di engines
41 Air temperature sensor
42 Fuel temperature sensor
43 TPS circuit
44 No faults detected
51 Injectors
54 AT signal lost
55 No malfunction in the above circuits
Note: If code No. 11 and code No. 21 are both displayed in the same incident, check the CAS circuit before checking other circuits.
1996 is OBD II
16 bits are silver.
My ECU isnt on that list?! LOL
2371M 41P14
A18-000 MC9K
3X01
Mine is apparantly remanufactured (has had a Mines Chip in it)
Fault code table
Code Fault
13 CTS
22 Fuel pump
32 Starter signal
33 Oxygen sensor
43 TPS circuit
51 Injectors
54 AT signal lost
No, the above are the fault codes as presented by the ECU when interogated by a Consul or ConZult diagnostic kit.
The numbers Shunter originally enquired about are the actual part numbers as labled on the outside of the ECU.
