I bloody hate shaving, I seem to get a rash now and then on my neck, was thinking of getting a good elecric razor but im not sure it will cure the problem of wet shaving????
I have a vibrating mach 3 thingy ehich is good but any one else have any ideas?? I know i'm 24 and should have worked out how to shave by now :slap: but hey.....what can you do :D
  • Replies 47
  • Views 1.3k
What Method Of Shaving Do You Use ?? 28 members have voted
  1. 1. What Method Of Shaving Do You Use ??
    • I use an electric razor
      10
    • I Wet Shave
      18
If there's spiders legs she aint doin it often enough :tongue: :rofl: :rofl:
:rofl: :rofl: :rofl: its called perimeter creepage
talking of shaving why do women shave the putang in the bath and shower (my missus) and not rinse down 100% and leave spiders legs all over the place :rant: :rant:
at least your misses doesnt have afro flange fluff, iv had the plumber out twice to clear the drain
Winner of "Best shaving technical advice" at 2007 300zx.co.uk club awards
:rofl: :rofl: ;)
whos this^^^^^^^^^^^^^^^^^
:rofl: :rofl: pure class :rofl: :rofl:
:rofl: :rofl: whats even worse she might be shaving for the plumber :rofl:
............and blamed all the pubes in the plug hole on greg :rofl:
:rofl: :rofl: :rofl: lmfao
Problem (for me) is that a blade shaves too close, the hairs retract under the skin which feels very smooth, but they become in-grown and then I have lots of lumps, the razor hacks the top off and I'm a mess ... So, electric with slimy stuff is the way.
mine do that and turn into friggin lumps and get razored also. Thank f##k I'm not alone though i was turning into an alien
Electric razors are crap! Its all about preparation - make sure you get as much HOT water on your face BEFORE applying shaving foam/gel. Then use a razor washed under a cold tap. I used to suffer big time but since doing the above, not a single problem :)
half the time i dont even use shaving gel. i wet shave upwards against the grain. exceptionally smooth shave and no rash!
before anyone says it after a couple of days my face is like wire wool so no jokes about soft stubble LOL
yeh you all laugh. You dont know the pain i get when rubbing against the snatch of this rough afro monofilant :smw:
Like velcro...... are you the hook or the loop Greg? :confused: :rofl:
Wire wool? Ask Big Kim about zedfest :rofl: :rofl: :rofl:
Personally I use both electric and wet razor. I use the electric while having a shower to do a 'rough cut' then clear off all the rest using a gillette fusion vibrating blade with king of shaves gel to clear up the left overs.
I've found it to be the most comfortable method
:x: ;) :rofl:
Best not :rofl:
leccy shaver if im in a rush but the full works if im on a promise used to go to this itallian bloke a few years ago he did the full works with the cut throat and hot towels i didnt need to shave for 5 days after it was awesome
I just bought a Reminton Titanium Electric.....the instructions tell you that you have to use it daily for 4 weeks till your skin gets used to it.
Before this I used a Mach 3 - (Bought the Fusion but it was useless too thick - one day I am going to invent the 115 blade razor)
Almost the same a Duff.......Hot water on the face, gel/foam lather up, then
1. down(with the grain) on the face and up on the neck. - to remove most of the long hairs
-----technically at this point you should rinse face and re-lather --- but I never bother -----
2. gently up(against the grain) on the face and down on the neck. - to get really close.
I got sick fed up of buying bloody blades all the time when I have to shave every 1-2 days. :( Hence the Electric - Plus when your running late you can save time and just shanve on the way to work!
and join us next week when we will be learning how to wash our necks :rofl: :rofl: :rofl: :rofl: :rofl:
Blimby, im inpressed with all the replies,
looks like i'll stick to wet shaving but do it properly!!! Think i might do in the evening so i got time as in the mornings i REALY can't be arsed to shave.
