I have decided i want to upgrade my brakes. i have a set of cast iron TT calipers and disks the calipers need a refurb as some of the pistions are siezed!!
i currently have the na aluminium calipers on my z . would i notice any difference with fitting the TT ones if i overhauled the calipers?
My 2ps worth say don't do it - change the rubber beake lines to braided instead - works a treat...
Good luck
Jack
Good luck
Jack
the thing is i need new disks anyway
tbh i dont think id bother bud. I dont know what the spec difference is between the n/a and tt calipers, but im going to guess theyre both still 4 pots.
Personally id go and overhaul your ali ones and get a good set of Goodrige braided hoses and brake cylinder stopper and a set of Performance Friction Brake grooved discs with pads.
The only other worth while thing i would think of doing is go for the whole R33 GTR brembo option. I remember how shite the brakes were on mine, and i know if i get another, the brakes will be the first thing ill be uprating!
Anyway, hope your well bud!
Nick
Nick
thanks nick im ok cheers. i was just thinking seeing as i have them staring at me with newish disks it would have been worth it! i will check out my calipers and see if they would accept 30 mm disks
It is worth it mate, as you know N/A discs(aftermarket) are not plentyful, they are a thinner disc and would benefit some from decent TT discs and fitting the TT calipers once overhauled. Add some new fluid and braided lines and jobs a goodun ;)
what year is your NA bud
i have been out and measured my ones they are 26 mm ones and the caliper apature is 28 so it a no go!
just been reading up on this smithy, and i may be wrong, but it looks like after 1991 NA discs were made the same thickness as the TT. Saying that i dont know what the diameter difference is between the two
thanks smithy.
my thinking is that i would be able to get tt stuff easier then na so upgrading with this potentially free calipers and disks would be benificial
after all this fitting stuff how easy is it really to bleed the system!?
TT caliper overhaul it is then!
daunting taking the calipers apart tho. will have to seriously look into this job as i don't like messing with brakes ;)
Sorting the calipers with a repair kit is really easy - don't worry.
I had a 97 Na (untill recently) and it had iron calipers and 30mm disks. I replaced the scruffy iron calipers with '90 alloy Na calipers - great looking - and bought some 2nd hand disks off Andy - and the breaking capabilities were just the same - but it dit have Goodrich braided lines.
Good luck
Jack
Ps - if buying second hand NA disks make sure they come from a manual and not an auto.
Good luck
Jack
thanks for all you info jack
cheers everybody going to go away and do a bit more reading up.
virtual :duffer: for you all
sorry bud ...but WHY are you paying for the cailpers and then, the re-building of them ..when you can get a set of GTR-R33/34's for about the same money ... :confused:
time for you to have a THINK ......!!!!!!!!!!!!!!!!!!!!! ;)
if you need help give me a call ....07798625541..
wozza....
wozza....
thanks smithy.
:p so if i can get a set of gtr 33/34 setup for between £50-£100 then im very intersted :D
sorry bud ... :mac1:
BUT I WOULD STILL GO FOR THE "GTR" brake's .....
but then again you DON'T go fast in your Zed do you ....... :tongue: :tongue:
wozza ...
wozza ...
i havent got the ££ for them LOL.
oh and your a cheeky scrote :rofl:
sorry bud ...was watching topgear .....BIT like your car .... :x: :eek: :tongue: :rofl: :rofl:
Reliable i know. didn't see any holes in the bottom of the engine on any of there cars :x:
you only get them ,then you drive your car "HARD"..... :tongue: :tongue:
I put black diamond drilled /grooved 26mm discs on mine, work great, defo improvement!
I put the TT setup on my old NA, can't say it made a noticeable difference.
The only reason I did this was because it was cheaper/easier to find the TT parts!
