wide arch's on an n/a
is there any wide arched n/a's and how difficult is it to do fancy the idea would give it a go but what additional costs are there involved no need to pay for a garage to do it as ill do it myself
Speak to Stellaz, he did his himself.
cheers mate will do
the cutting of the arches is actualy quite easy, its quite heart redering lol, you get templates for the cut out's, what you have to do is cut the outer arch away(using the templates ), but leaving the inner arch in place, then you have to cut up the inner arch to where you have cut the outer arch off, then fold the inner arch out and weld it to the outer arch for strength, you will see what i mean in the first pic of my thread, the bits that stick out of my arches is actually the inner arch bent out
fully underseal the cuts and the weld
actually fitting the arches is not too bad if you know what to cut off to make them fit, unfortunately i didnt take any pics as to what to cut off, it only took me, my dad and peter from pps about a day in all to cut the arches and fit the kit, (when say day i mean about 12 hours)
there is a lot of fibre glass that you have to cut away from the arch kit to make them fit, but once that is sorted, its a matter of linging them up prefitting them with self tappers and fitting the rest of the kit to see if it fits before gluing (use fibrol) to the car
