Smoking
My Z has started smoking from the drivers side exhaust! it is a white smoke and there is also water in the tail pipe, the exhause also goes white frome time to time! could this be the turbo? or is it more likely to be a head gasket ?
any help apreciated !
White smoke? Sounds more like water, but before you panic and think head gasket. Are you losing any water from the cooling system? The mornings are colder now, could be condensation in the exhaust.
it did start when the engine was cold! now it is smoking when it is warm!
What about after a good drive?
I mean when the pipes are hot too.
Are you loosing any coolant?
i am loosing a slight amount of coolant but not much ! i am loosing oil tho which dosent make much sense!
I know, but the smake is normally white! and the exhaust goes white which would also sugest water?
