hi all,
is it true that sard make the nismo 550's ? if so im guessing the injectors are the same but just branded under a different name?
thanx
I believe Denso are the manufacturer for Nismo and sard.
I thought Denso and Sard were 2 of the few injector manufactorers. + i haven't seen or heard of any Jspec 300 cars coming in with aftermarket Denso injectors, but plenty with Sard and Sard regulators. Hey I maybe wrong, but either way the Sard injectors look the same as nismo's and are known to be reliable.
Denso make and test the injectors and then sell them to Nismo and sard to remarket them ..they are a lot lot cheaper than nismo 555's and are exactly the same item .......just try and find a distributor though :(( sorry for hijacking the thread but are skyline and z32 injectors the same as lots of guys on the SOC run Denso injectors . maybe they know where to get them from .........
Cheers steve
Thanks for clearing that up. The Pre 94 Zed use a side feed injector, but the post 94 cars use the same injectors ar the skylines, but they are all nissan and Nismo there as both you and Dave have said "Denso's" and not sard as I thought (because they're indentical)
