Mines ecu
Just got hold of a mines Auto ecu for a future upgrade. is sealed with gold plate and tags mines japan. I have cat backs an an apexi. next to fit oil cooler & PCV's in december for later power upgrades (boost control). Can I put this mines ecu in now at standard boost So i can get used to driving it? I understand I will get no more power fron it also what fuel to use JDM Auto with this ecu optimax current. Cheers
yes and yes ;)
mines got one on... (No pun intended) and its fine.. Infact i didnt even know it had it until i came to pull the ecu out to send it away to be chipped... Bless my car, its full of suprises!
I hope mine aint already done yet grr I assumed not as everything sept zorst was stock when I bought. Cheers all
Also Ehat boost will this ECU run?? I plan to fit new boost gauge and 1mm mig tips would this be ok or safer with 1.2mm
thanks in advance
sorry is vpower not optimax I use. (if this is better or worse than optimax)What boost can this ecu run safely with correct cooling etc.Any users of this ecu
Vpower is same as optimax just rebranded
