Plenum Removal
Hello all
Asabove tried to get the plenum of today spent about 3 hours at it including compression test, anyways its pretty free but just wont come of, so looks like theres something else holding it, is there any sneaky screws i dont know about, coz after a while i threw the towel in. Also when taking the intake pipes of found the inside of the lower right hand side to have a bit of oil in it????
Just another thing, when i get this thiing off, is it worth doing the by pass, and could i rip the egr out???
drivers side has a oil hose going to the turbo. Is that off?
10mm bolt below the passenger throttle body securing the turbo coolant feed. Check both PCV hose clamps are off and that all water feeds disconnected.... Oh and the EGR tubes underneath :)
thanks guys, its off,
Small screw on the coolant hose to the passenger side turbo, and a couple at the back drivers side, had to cut a couple of the hoses as just couldnt seem to get the buggers off. Anyways read about the egr removal and the aiv was it, is this worth doing, as at the moment im dreading putting the thing back on, so many hoses all overe the shop lol. Never mind gotta keep going till i get the head gaskets!!!!! Infact im might take the lot out, could really do with a look at the passenger side turbo.
