Front shock absorber removal
I have finally started unbolting stuff on the front suspension subframe to drop it so i can get to the passenger turbo to replace it (yes i know :wack: ). I am being a good lad and taking photos with phone and labelling bolts and stuff in clear bags.
How do i unscrew the front shock absorbers at the top to drop them? They have a bolt with a straight shank on it at the end and a bolt screwed on it?
Just changed mine today! You dont want to undo the center bolt, that holds the spring seat to the shock shaft. Undo the two bolts on the outside
of the hole and it will drop right out. If your not sure what I mean I can post a picture.
