July 7, 200224 yr does any body know where to get this from an how much? cheers Kris ------------------
July 7, 200224 yr Yeah. Gavin Scott at Delta Oils (UK Distrubutor of Redline Oils) Phone 01476 861195 Normally £15.60/945ml, if you are in a club £12.50. If you buy a few, which you'll have to you get free next dey delivery.
July 7, 200224 yr Hi Cris, My honist first-hand advice is. Don't put redline, or any other non-nissan specified oil in your box unless you are 100% sure. Only put redline in (say MTL) if you are having big gear box problems. FYI - Putting redline MT90 a new box killed mine... don't do it! If your box is already okay, stick with something similar I would reccommend Semi-Synthetic (otherwise fully synth) 75W80, 75W being important. Regards.
July 7, 200224 yr My G'box was shagged, drives like new now though. No crunches anymore. What did MT-90 actaully do to your box, and how do you know it was the oil that caused it. Not doubting you BTW.
July 7, 200224 yr I put MT-90 in my gearbox at 51k miles and have had no problems in 8k miles since. Much improved feel to gear box changes after about 500 mile run-in. Jez, perhaps your experience was because your gearbox was new and "tight"? -Andrew
July 7, 200224 yr when cold it is verry stiff in to second, geta slight crunch. also have been getting a crunch going in to fourth when going both ways through the box ie. 5-4 and 3-4. herd this can be normal but wondered if the redline trick would work? ------------------
cheers Kris
