Engine trouble ?any words of wisdom?
Hi all
my 300zx has developed a problem when the car eventually starts it runs for around 20 minutes hen jus cuts out( like the ignition has been turned off) the weird thing is no management light comes on, so im guessing that its a problem with a sensor like the air flow meter, map sensor etc and it appears the problem occurs when the engine is warm, so i was wondering if any one knows of any common problems or a way in which i can diagnose the fault as im guessing no fault codes will be generated as the management light doesn’t come on, any help would be greatly appriciated.
its a 93 k reg twin turbo auto
Tony
