In memory of Mandy
Misfire! managed to bring up these codes, what now???
As many of you know i have been experiencing a misfire in 4th gear on boost, however i have just done a self diagnostic on the cars ecu and codes 33 and 53 came up, i believe this is to do with oxygen sensors(not maf) , is this true?
ย
Also what do i do now...?
that is both the o2 sensors
ย
11: crank angle sensor circuit
12*: air flow meter circuit
13*: engine coolant temp. sensor circuit
14*: vehicle speed sensor circuit
21: ignition signal circuit
26*: boost pressure sensor
31*: ECU
32*: EGR function
33*: exhaust gas sensor circuit (left)
34: detonation sensor circuit
35*: exhaust gas temp. sensor circuit
42: fuel temp. sensor circuit
43*: throttle position sensor circuit
45*: injector leak
51*: injector circuit
53*: exhaust gas sensor circuit (right)
54: signal circuit from A/T control to ECU
55: NO malfunctions in the above
ย
*Will cause the Check Engine light to come on under normal (MODE I) operating conditio
The sensors share a common earth and feed wire.check these for continuity.they are fused by the engine cont fuse as are the rest of the sensors/solenoids but if this had blown youd have loads of other issues.you should see 12v at the red/black wire and should get a variable voltage on the middle wire when you rev the car.this is the wire that signals the ecu.they enter on pin 29 and 55 of the ecu.
