October 11, 200718 yr i have recently purchased a 300zx and have alot of questions but i'll start with this one. what is the overdrive button on my auto box and is it best to drive with it on or off?
October 11, 200718 yr With my old auto, I had it off most of the time and would only put it on if coming up to steep hills, climbs or where ever the car is under load. With overdrive, It won't shift a higher gear then needed to (when turned on). Basically it's like you wouldn't drive up hill in your highest gear, but appart from that, overdrive didn't make much of a difference in my old Z anyway. Someone told me once that it's like a go faster boost button which didn't help :P Keep it off/on to load.
October 11, 200718 yr Leave overdrive on unless you're caining it. Its like an extra top gear. Leaving it off for prolonged periods will cause the 'box to fail prematurely
