question about pinking!
hi there, car is up and running and enjoying it, boost controller fitted and holds boost perfectly, I am boosting to about 11 to 12 psi, only problem i get is that sometimes as I accelerate I can hear pinking, I have checked the ECU and get a code 55 so thats all ok, done the timing and thats spot on, so any ideas what would cause this? do I need to chip the ECU to provide more fueling under acceleration? anyone got one spare, lol
Brian
pinking - dett right?
if so only happens when running lean
so..
bad injectors or connections, blocked fuel filter?
chip deffo the way to go
My cars always PINK in !
Brian
At 12psi you're right on the edge of what the standard map can handle, so you should get your ECU chipped for safety.
cool, sounds like I need a chip, anyone got one, I am handy enough with a soldering iron, my car is 1993 uk spec TT auto.
yeah but i bet it looks better on you than me, lol
