Low speed driveability issues?
Ok I live in London and that is an immediate conflict with owning a 300!
But have notced that when poodling along between 1500-2000rpm the engine doesn't really like it, anyone else having this experience?
Everything else on the engine is fine as much as I can ascertain ;)
Some people have upgraded their recirc valves on the sxoc and notice that this has gone (ok different engine), and I am wondering that maybe the nearly fully closed throttle at low speeds is causing this problem?
Not a technical answer but, I always leave in 3rd unless Im going downhill at 35 and above then I put into 4th. So in otherwords I agree with you.
Mine is fine. Don't think it's ever run better since I removed the plenum, had all the injectors cleaned and replaced all the electrical connections.
uumm I did have no.1 injector paying up but now it is behaving itself may have to do some investigation, who cleaned and flow tested them for you Andy?
It was Mario, at this place :- http://www.theenginetuner.co.uk/
