Engine coming out next week end what do
I need to look for whilst removing engine ie: parts that should be replaced while it is out.
Did read on here some where that engine mounts should be replaced?
any help would be most helpful
regards
Dave
I need to look for whilst removing engine ie:parts that should be replaced while it is out.
regards
Dave
depends how much engine work your doing but the following are general parts idealy to replace whilst engine is out
(turbo replacment)
turbos :p
EGR removal not vital
pcv valves and all 5hoses
all relevent washers and gaskets to turbo region
make sure you replace oil feeds to turbos about £100 a pair but dont scrimp here :wack:
rear oil seal!
front oil seal to crank (easier with engine on stand of course)
plenum bypass, or replace all hoses to coolant feeds.
cambelt and tensioner (unless done recently)
waterpump^
oil&filter
coolant
engine mounts over time perish and alot of the time fall off when the engine is lifted. worth having a spare set of good used! or new ones on standby.
dont forget to check transmission ie clutch replacment,spigot, skim fly, release bearing makes this an ideal time to replace.
check for any PS leaks now, this is the best time to fix those common leaks between pump/rack
(obviously if engine work is nes)
then full gasket kit, and everything else with engine is an obvious choice.
people can add if iv missed something.
the aim is to replace parts that may fail with age, rather than leaving things like rear oil seals means transmission will need to be removed in future for the sake of £20 :smash:
good luck bud, greg
(turbo replacment)
turbos :p
rear oil seal!
waterpump^
oil&filter
coolant
good luck bud, greg
Cheers Greg good info there [have done some of those already ] but useful info as always
Dve
As Greg said , plus rocker cover gaskets and re-seal ( 2 have gaskets and 2 are sealed) , also rear core plugs . HTH
Be prepared for possibly having to replace the EFI loom. In fact I would highly recomend doing so. They dont like to be disturbed and you'll have hard brittle wires and broken connectors to deal with.
Dave is this still available?
Thought was obsolete!!
The overpriced RHD version is apparantly sold out....but plenty of LHD looms available, SWZ has half a dozen on there shelves.
No fitting issues, You just have an extra foot or so of loom that you place under the battery tray.
Cheers Dave will give paul a shout :p
Where can i buy oil lines for the new tubs,is it best to go OE
I had to change all the injector connectors as they are rubbish once disturbed
got rid of plenium water feeds, egr, aiv, air con and hicas while mine was out
regards
Dave
Good luck,Dave ;September came around quick and the Yellow z gets what it needs
Depending on engine work being done?
Clear old casting flashings from the block
Send off injectors to be flow tested and cleaned
Replace Det sensor and det sensor loom.
But pretty much what greg said!
If you do a search for this there are quite a few posts, they are old bits where they formed the block originally and block the flow of coolant to the rear cylinders!
