throttle hesitation when ist started
any help when started from cold after a minute or so drops to 750 rpm then hesitation on accelarater [slight foot presure] rpm drops 200 to 300 sometimes cuts out then up to 750 again [no problem when warmed up ]advice things to check ? :duffer:
Check the Yellow temp sender for corrosion ( the one on the top alloy water pipe ) clean sender and connector , the dreaded green corrosion can cause this . HTH
Had the very same problem my folically challenged friend lol.Fitted new water temp sensor today and also wired in new plug at the same time.Runs smooooooooooth as fook now. :dance: :dance: :dance:
