Compression test
Anyone know if it's possible to compression test an engine not in the car??? If it is possible how is it done, I have a tempoary engine to put in the car and want to make sure it's ok before I spend a few days doing it. I know I could take the heads off to check pistons/valves etc but as it's only tempoary I would rather not!
Ger hold of a zed gearbox bellhousing (or complete gearbox) and starter motor with a 12v battery
Gear box is still in car. Would mean getting the engine in and connecting it to the box and some of the wiring, also the engine is from a manual so would need to change the bits over. I was hoping there was a way to do it out of the car to save alot of work. I think if I did that to find bad compression I would :hurl:
ย
That will still work won't it :confused:
Mine is an Auto :mad: Any other way?
You could use the autobox bellhousing!
auto or manual makes no difference. No wiring change or anything else needed.
ย
Unbolt bellhousing from autobox and bolt up to engine. Bolt on starter motor and use 2 piece of wire to connect a 12v battery to the starter which will cause it to run and turnover engine.
ย
ย
Thanks, didn't realise I could get just the bellhousing off. Thought it was whole box out or engine back in to get them together :dance:
