I bypassed my det sensor with a resistor about 6 months ago and got rid of the code 34. I have had a new engine fitted since then and have been told that the sensor was working fine on it before it was removed from the other car.
I was at Zfest the other week and was told that with the resistor fitted it will get rid of the error but the ecu will still know the difference as the sensor normally gives different resistances, not the constant 1k ohms. He also said that it will still run safty boost and the timing will be retarded.
I have a boost controller which overrides the safty boost but I'm worried about the timing being retarded due to this. i asked him to check the timing on the consult to confirm but he said the the consult only reads what the ecu expects, not the actual timing?
Now i know that the resistor will bring a normal car out of safty boost as so many people have proved so he is wrong there but anyone know about the timing / maps the ecu will use (JD chipped ecu).
I could reconnect the sensor now as I should have a working one but is it worth the bother?
