Do you have to manual bleed the brakes??
I am changing the brake pads and upgrading the lines to braided lines today. I just have a quick question about bleeding the brakes...
Does this have to be done manually or does anyone have any tricks to make this easier/quicker.
Cheers.
Yep, same way as you always bleed brakes (except when you have a Citroen with the Nitrospastic suspension).
Front calipers, rear calipers, ABS unit
Yep - fronts are furthest away just to clarify ;) They have the longest route since the lines run from BMC - ABS unit - Calipers, so the front lines run to the back of the car then back up to the front :)
