H.I.Ds
just fitted my hid kit and one of the bulbs strobes and goes out ive checked to see if the wiring was wrong and tried using the other ballast but it still strobes and knocks off is the buld fubar'd need to sort it quick before the local chavs thinks theres a rave going on in my garage
cheers in advance
sounds like you're not getting enough current to it, i had a similar problem with mine but, i had an after market kit which dimmed the lights when the car had stopped moving. not saying you have that kit fitted just, it sounds like the same sort of thing when the power goes down. have you done a voltage check including continuity? maybe theres a bad earth or open circuit some where in the line.....
cheers in advance
Hiya bud, just realised you are the guy i bought my exhaust system off, how ya doin - except your HID kit of course. lol
I have just paid for a HID kit from a company on here, did you to - do i have the same problem to look forward to. lol
cheers in advance
cheers in advance
hi mate hows you doing hope that zorst was loud enough for ya lol
hi mate
yeah done a check and it all seems fine the only thing i havent done is try the dodgy bulb on the n/s connector instead of the o/s im off to try that thanx for replying tho
I'v actually got used to it - sounds insane really does'nt it, cos everyone says it is LOUD! I drove to edinburgh and back a couple of weeks ago 400 miles, i think i just became immune, also loud music helps. TOTALLY WORTH IT, the way people look in disgust when i go past. lol
lol i used to downgear when i passed someone and it used to pop was so funny watching them jump ...childish but funny glad you like it bud hopefully ill see it in the flesh sometime
cheers in advance
Hi,
Check the "suspect" bulb on other ballast wired up to the other side of the car (meaning, if the suspect bulb is currently wired up on the driver side then wire it up on the passenger side using the other ballast). This will help determine whether it is (a) the bulb, (b) the ballast (although by your own description it doesn't appear to be that) or © the car's electrical wiring.
I don't think you got the kit through me but if you need a replacement H3 bulb quick I have several in stock (provided they use the same connectors).
Dan
