changing the pedals manual conv.
I've searched and searched but is there any info on doing the pedals for the man. conversion. I'm thinking brake pedal could be just "shaved off" a bit,I have a pedal to put in if not. If anyone knows of any other links than z1 motorsports?
I'm trying to print off as much info as i can for the garage, I think it would of help great help to him. He's a good mechanic but never worked on a 300 before so any time saving, frustration saving tips would be extremely grateful. he reckons the pedals will be the trickiest bit.
I found loads of lists for the conversion parts needed on a search, but not too much info on what not to do, common mistakes etc.
thanks in advance :)
You can cut the auto pedal down(that's what I did) but if you have the manual one may as well fit it!
When I fitted the clutch pedal (n/a) it wasn't too bad,just got backache LOL!
Yours will have a booster,so might be trickier! :wack:
NA is simple 20min job
TT is a fiddle, but if you have done a heater matrix bypass before on a manual you know what to expect, its just awkard really
you can cut the pedal down with a grinder, use a brake pedal rubber as a template draw around it and cut! just cover the floor and surounding area, otherwise the sparks will burn your carpet!
we use a hacksaw and cut it slowly rather than singing the carpets LOL
be quicker to change the pedal than use a hacksaw :wack: :p
we use a hacksaw and cut it slowly rather than singing to the carpets...... LOL
La La de de........ :dance: ........ :wack:
