indicators and clock not working
Everything is working except indicators, the hazards work, and no power to the clock, any ideas which fuse it could be, mind you, think i have pulled them all and all ok :confused:
i would have thought that if it was a fuse, your hazards would also not work... the clock is renoun for its 'unreliability' so maybe the 2 arent linked? possibly a faulty indicator stalk?
Fuse but can't remember which one lol
But I'll check the wiring diagram tomorrow and let you know :)
Ye i shorted the clock feed while fitting a stereo
The indicator fuse itself is ok !
cheers bud
Had a similar problem on mine, try wiggling the hazard
light switch, sounds daft, but it worked on mine! :p
Yep. Mine did that as well. If it dosen't sit correctly then the indicators don't work for some reason.
Darrell
Doesn't explain the clock though lol
my indicators have stopped working before now.... a short sharp belt to the steering column fixed it... :)
Darrell
Yep, daft as it sounds, 'tis true.
Seen it a couple of times now myself.
hopefully that will work then...will try tmw, cheers guys
Yep..... that worked :)
cheers guys
just the power to clock now...
