Adjusting the TPS/Base idle
Followed both the write ups by AlFo (FAQ 3rd July 2007 17:17) for adjusting TPS and then the Base idle.
TPS set to 0.46V.
Then, Using the ConZult to monitor revs while adjusting the base idle switching on and off and removing the batterery in and out to get at the Base Idle Screw. However, when i put the yellow plug back and restarted her, she idled at about 600rpm and then cut out. When i restarted she's now back up to 16/1650 rpm....When i select the idle adjustment in ConZult she drops back to 900rpm
.....Leaving the battery off for 30 mins to re-set the ECU, but anyone got any other thoughts???
make sure the closed throttle switch has been reset: it should be "ON" at idle.
if it isn't, disconnect the grey TPS connector (the one that's on a separate wire) for 10 seconds while the engine is idling
Cheers Lymon. Seems that the battery off and ECU re-set did the trick, but i did what you said as a further precaution and it's sorted.
Thanks again.
Damian.
