Apexi Boost controller help
Has anyone got a boost controller, I have set it up at 1 bar, i have set it a 1 bar from 3000 revs upwards, is that right or should i do a gradual build up to 6500, also what do i set the duty at, i dont understand the duty?
what other mods have you done, i guess you have chipped the ECU as well? If you are trying to run at 1 bar with stock tubs, injectors, intercoolers then you will be pushing the stock items to the limit.
its chipped yes, i asked the question if it would be safe running at a bar and everyone said yes
yes you can run at 1 bar but for how long? As i said you will be up to the limits on old stock injectors, tubs etc, your better to run about 12 to 14psi max on stock, save a bit of stress on the engine.
really you need to know what your injectors are doing and your a/r throughout the revrange, mine is chipped and runs 14.5 psi with a good a/r for safety and still leaves the injectors at 80% duty cycle most of the time
1 bar fine all the way through to redline - tbh you'd be lucky to make much more on stock components...
