OK To Run 18's Front + 19's Rear ??
Hi gang..
I have found a nice set of wheels for sale.. But they are:
BLITZ
Front - 18" diameter, 9" wide with a PCD of 114.3, offset 41.
Rear - 19" diameter, 10" wide with a PCD of 114.3, offset 45.
Tyres - Pirelli P Zero Rosso, 235x40x18 front.
Pirelli P Zero Rosso, 275x30x19 rear.
Are there likely to be any fitment issues with these??.. I've never fitted different sized wheels, front to back before.
They are to be fitted to my wide arch zed.. Currently not lowered.
Thanks!!
you'll need spacers, about 15mm on the front, and probably 60+ for the rear to fill the wide arches
Yep.. I wondered about the rear offset.. It's bad enough fitting 10J, and needing to fill the arches, that offset doesn't help things.. Don't think I want to be driving around on 70mm spacers :wack:
O well.. Back to the drawing board.. But I think I will do 18 +19 in a different wheel, maybe Ultralites ;)
Appreciate the replies anyway guy's, thanks!! :D
ABS might act a bit funny??
the only way to avoid spacers on the rear would be to have a negertive offset on the rear unless you go for a 12" + wheel
PWR in Blackpool would sort you out with a nice set 19" of EVOX 3 piece with Perrelli RossoTyres for about £2700. That would be a 9J front and a 12J rear.
Oh right.. I suppose the Hicas wouldn't like it much either :confused:
Better stick with one size then LOL..
Thanks Duffers ;)
Thanks for reply also Markzx.. Not looking to spend that sort of money TBH, I was hoping for under £2K ;)
Might just have to get mine re-furbed, and new rubber.. Fancied a change though :(
Do PWR have a website Mark?
Providing you alter the tyre profiles to ensure that the rolling circumferences of the wheels are as close as possible then it should make no difference!
If you stick with 18s then you would have (say) 265/35/18 rears and 235/40/18 front - most owners here running 18s have those sizes. So if you went for 265/30/19 on the rear they would be the same size overall as the 265/35/18.
No problem!
Richard :cool:
No problem!
Richard :cool:
Thanks for that info. Richard.. So there are ways and means.. OK, it opens up my options again.. Many thanks!!
