Engine Electric Cooling Fan
When carrying out the test to check your Electric Cooling fan is working, i.e., disconnect the water temp sensor, turn ignition on, and the fan should cut in, if OK that is. should it run continually then until you switch off, or only momentarily as mine does. It runs for about 2 seconds and then turns off. Has the relay gone faulty ??
continuously I believe !
Oh B****x, I must have another problem as well :mad:
