protoj ·
was sat at the lights with foot on brake pedel..as you do
then suddenly the pedel buzzed and bounced and then the abs light came on .
tried everything to turn it off but it didnt went a mile up the road parked up for ten mins started her up no light ..hasnt come on since
any ideas
cheers
