electronic hicas ?
yours will be the good old hydraulic hicas like mine, only came out on later models
deffo my 1994 uk had hydraulic. also you would have the hicas unit at the front of the engine bay on the left
The way to check is to look at your power steering pot. If the cap has two wires coming out of the top then you've got HYDRAULIC HICAS whereas a top without wires is ELECTRONIC HICAS.
Dan
PS - Electronic HICAS is on late 1994+ models IIRC
