Datascan USB AAARRRHHHHHHHHHHH!!!!
Help please if anyone can, I have a USB datascan cable, the drivers load ok and the PC sees it as a com port but I cannot get it to talk to the ECU no matter what I do, the consult port seems to be loose on its wires just above the bonet release on the drivers side. is it possible my consult port is Fricked is there any tests I can do to test it? anyone else got the USB cable working after having similar problems
Brian
Have you changed the Port settings to match the correct Port number being used, in the Datascan prefences tab ?
Also sometime with usb drivers you need to manually add the driver again going through the device manager, not just run the setup program.
yep it sets up as com 7 I have set the sw to that with no joy, and I hve tried to manually install the drivers again, no joy, comp is happy that it there and working, software doesnt object to the port setting just nothing from the car!!
when I was using cp210x drivers mine would'nt work, I tried cp2101 drivers and it worked, I'm running vista on a new laptop. The setup file is 1.5mb if you cant find the drivers on the net I could send them to you.
Legrath, when the pc's detect it it says Cygnal USB Composite Device and for the port it says CP2101 USB to UART Bridge Controller (COM 7) so should i be using the f
Legrath, when the pc's detect it it says Cygnal USB Composite Device and for the port it says CP2101 USB to UART Bridge Controller (COM 7) so should i be using the ftdi driver? could this maybe be the problem, I downloaded the Cygnal drivers from the Blazt website, would these be the latest ones?
Thanks for help so far
Brian
mine done that, i just tried changing the com port and it eventually worked
Brian
Most run fine with the old drivers, but some have had problems, they have just released these new FTDI install files, I would give it a go.
tried them no joy tho, wouldent install it said no compatible hardware detected, thinkit must be a cygnet type!!!
yes cygnal and ftdi are two seperate, incompatible chips. i think blazt are finally using ftdi chips (which are better, particularly drivers).
The other option is to try it on a different Z. Is there anyone local that you could try it on. At least that would narrow it down to the laptop and not the car.
Darrell
yep thats what I thought Darrell, will look for willing guinea pigs, lol
Brian
