ethanol E85
ive heard Morrisons sell this in England, but is there a petrol station locator i can use to find out where about in Scotland they sell this stuff??
ive tried google but i just get dead links.
cheers
Hi mate.
Not sure if it will help but there is a link at the bottom of my sig to cheapest petrol.
Darrell
might be a stupid question, but can the 300zx TT run on Ethanol E85?
yes, but it will kill the injectors after a while.
Apparently this has something to do with a chemical reaction that causes the fuel to corrode/react with the injectors, since the injectors on a 300ZX are always powered by 12V (even when the car is not running)
It's good fuel though...higher octane then regulare fuel
> not without MUCH bigger injectors and a full re-map
that's only needed with full ethanol blends.
ethanol has a 9:1 stoich, while regular fuel has a 14.7:1
you will still need a remap, read Dave Walkers write up on it. you need to run a lot more fuel to get to stoich than you will with petrol. sure ethanol has a 9:1 stoich but E85 is a ethanol petrol blend.
its recommended that you use pickled anodised tanks fuel lines etc as the ethanol has O2 in at a molecular level and therefor can cause corrosion in a steel or un pickled alloy tank.
the reason that most of the E85 pumps are locked off is because it wont run on any cars without modification.
i dont see what problems you can percieve with the injectors, all injectors use a live feed and are pulled down to earth by the ECU.
