fuse box
does any one have i drawing or foto of the small fuse box cover inside the car on the drivers side
i have a jap import n/a manual and its all in japanese.
funny that eh?
my lights, front and rear have gone and also the clock lights and i dont know where to start
thankyou
matt
thanx for the diagram,
if the dim light relay in the engine bay is nackered would this effect the rear lights.
i have brake lights but no normal lights, only high beam, also the speedo lights are out
i thought the dim relay is to do with the diped beam coming on dim with the side lights and was only a uk thing. could be wrong
can you confirm which lites don't work: side, dipped, full beam, hazards, rear etc. and any mods like hids
as i under stand it the dipped and full beam use the same fuse and the relay selects which one is on. seperate fuses and relays for left and right.
so i doubt the problem is with the fuses unless it is the main lighting fuse or supply or ground to the lighting control or fuse box
these pictures may help: (click each picture to enlarge)
[sIGPIC][/sIGPIC]
i have no side lights,no dip beam, no rear lights,no speedo lights
i have hazards,brake, indicators,oil ,batt.
all the bulbs are ok and looking at the fuses they seem to be ok aswell.
i dont no about the relay as its sealed and at the mo cannot find a new one in this 3rd world country
