leaky targa's
Hi i have some drips coming in are the rubbers super expensive oh can a sealent of some kind be used.
Try some petroleum jelly on the rubbers apparently it expands the rubber very slightly but enough to give a watertight fit, worked great on mine.
£175 for the door rubber and £40 for the bit on the Targa ........ plus VAT. Well that's what I paid recently.
I tried various things to get rid of the leak, in the end decided the best thing was to do it properly and replace the rubber. It was a pretty straight forward job and no more leak.
You might be able to get a second hand one cheaper, but I wouldn't reccommend it as there's one corner that has some sticky pads, so not sure they'd work as well second hand.
Gaz
there is some rubber restoring stuff on sale in halfrauds i was told it swells the old rubbers to make a better fit...some members on here use peanut oil....however i used araldite under the joins by the targa drain holes...worked a treat nice dry leg :)
