Engine Assembly time.
Managed to get the heads back on, all the lifters and cams torqued down again, then fitted the cam gears and went to do the belt.
Not as easy as i remember it a few years ago so had dificulty getting the marks to line up with the crank pulley at the bottom.
I'm guessing the sprocket is slightly out so i'll try again tomorrow, but need to find some clamps to keep the top done.
By
JaiKai ·
Ok if you read my previous help post ive just seen suffolkzx (thanks again mate!)
He thinks its a boost leak, anyone else got any thoughts on that?
Or anyone with a boost leak detector close to norwich? :wack:
