Any Issue's With Fitting These ?
Hi Gang,
I'm considering these wheels for my wide-arch zed, to brighten it up a bit..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=230160238400&ssPageName=STRK:MEWA:IT&ih=013
Anyone have any thoughts on fitment issues.
I'm not after who likes them, and who doesn't like them.. Just fitment opinions.
Any advice appreciated..
Thanks!!
Ian, get some Ultralite's:)
You'll need spacers on the rear wheels. Whilst fitment is for OEM PCD/Offset, you'll need bolt on hub spacers to kick the rims out into the arches for wide arch. 9.5J @ 35mm will leave them well inside your arches.
Check with the seller too on centre bore size. Without Spiggot they should be 66mm. I have a feeling GTOs have a different centre bore size. Not by much though. Might only be 1mm (which I think it is), in which case you'll be fine. But any bigger you really want to make sure that spiggot rings are included.
ADRs are popular in the US actually, many of the Z32 guys roll with these. So the rims should be fine and I'll be the specs are identical.
But do make sure you get some decent bolt-to-hub spacers/adaptors otherwise it'll look like this...
I have et 35 offset on back of mine no problems ( the company supplied et 30 at first and they stuck out past the wheel arch)
The wheels in pic have et45 offset.
Elmo, yours is not wide arch though remember. Different parameters apply when fitting to a wide arch Z, hence the reference to Stellaz' car before he fitted spacers. :)
NB: That wasn't meant to sound patronising
*hides*
:slap: Doh !!!........ good point that man..
