plenum removal advice please
valve cover oil leak plenum removal any detailed advice on this ? can v/ cover be removed without cambelt removal help please
you can remove valve covers without the need for cambelt removal!
things to change whilst your there if not replaced recently
new
intake manifold gasket
pcv valves and 5 hoses (silly not to)
new sealant to half moons at back of heads to rocker cover
new bead of sealeant to both exhaust covers
check seal on both intake covers
plenum bypass, (if your not sure) just check and replace any suspect hoses and make sure there sealing well
thats it
tips on refitting intake hoses to throttles, heat up on top of a radiator so they become soft its such a nightmare trying to refit these when there brittle/cracked and stiff :wack: spray as fine mist of wd-40 on the inner rim off the hoses so they slip over the throttles
another vital is to make sure the intake gasket is 100% straight when you bolt down plenum, if its not you will notice your car sounding like a tractor! in the event it happens you may find you will thow the 12mm ratchet at the dogs head :smash:
i normally put a very small dab of s.glue on each corner of the gasket this will prevent the gasket to move and help align the bolts through the plenum
greg
thanks greg just hoping valve cover oil leak not head cant see whats leaking untill plenum off thanks again
more likely valve cover bud
Just took the plenum off mine to locate the fooked tappets, Its not too bad a job, good luck, and when you drop something even more luck trying to find it
