12v ignition live that stays on when engine cranks
Hi
Does anybody know of a wire I can splice into that has 12v when the ignition is turned to the accessory 1 position, ie when the clock illuminates up, and keeps the 12v even whilst the engine cranks over. Everything I have found so far does not keep 12v whilst the engine cranks over.
Colin
I would have thought that when the engine cranks over, 99% of battery power is used in actually turning the engine.
That would give the impression that a 12v live circuit (eg the clock) is not live during cranking, when in fact it is. You are probably just experiencing a power drain from all other circuits when you turn the starter.
Richard
you could use pin 109 of the ECU (white wire).
http://twinturbo.net/ttnettech/tc/tc02.jpg
It holds 12V when cranking and holds power for about 5 seconds after you turn the ignition off.
ideal for (boost/traction/fuel)controllers
don't use it to feed things that need a lot of power.
Thanks Lymon. That will be good to know for the future, as I don't need it for my gauges anymore, as I have been in contact with Prosport who have confirmed that they are supposed to turn off when you crank the engine. So I actually have wired them ok already, which is surprising for me!
Thanks again
Colin
