help please
having problems trying to get engine off auto box in car lifts so far with the hoist then stops lifting engine and starts lifting the whole car can anyone give me some pionters please what am i doing wrong thanks in advance
p.s as many pointers as poss please :hyper: :bow:
  • Replies 26
  • Views 885
Remove the prop shaft and undo the gearbox support bracket then either jack or support the gearbox or just drop it down. Makes it easier to remove the engine, at least thats what i did.
Have you undone the torque convertor bolts.?
were are the torque converter bolts
also were do you you slacken the propsahft :headvswal
the above link doesn't seem to work anymore! Will try and find you another.
dont need to remove the prop, pointless! not digin at you bigsss, just not required ;)
once the torque convertor is removed it will pull apart!
use the online manual in the links at the top right hand corner of the website, you will find what you need
good link there from that man
also if your removing the aircon pump, remove the awkward bolt when the engine is lifted up slightly you dont need to struggle like they do. Crows foot bloody yanks LMAO
I was changing the box anyway (with your old autobox) so had to remove it.
Still have not driven the car yet lol.
:eek: :rofl: come on sort it bud ;)
If he can''t see the torque convertor it would seem that not all the bolts have been removed from the gearbox as when he was trying to lift it then the engine and box should have slpit?
true, like you say its either a bolt left in, or the torque convertor is bolted up! but still the engine will split with torque convertor its just fiddly and difficult to pull apart and the mess it makes :nelson: drank dextron iii a few times not good :mac1:
Its taken over my life lol. After getting the engine and box in i removed the plenum PAS pot and balance bar for polish and chrome, then i bought viper front wings then strosek front and rear bumpers then found out the rear is for a wide arch so thats the next purchase. And i've been making a SS one piece slam panel and i've been done for no tax, insurance or MOT all this and i haven't sat my ass in it yet. lol
Anyway back on topic. :headvswal
i still need to no what torque converter bolts are what they look like and where they are aint got a clue were to look for these dont even know what they do :headvswal
If all the bolts are out of the bell housing when you seperate the engine from the box inside you will see the torque convertor, there are 4 14mm bolts that have to be undone this will allow you to get the clearance you need to remove the engine.
You will have to rotate the torque convertor and undo them one by one (the torque convertor looks like a big metal dome but you will probably only have an inch or 2 gap between the engine and box), like Greg says its fiddely but once you have the four bolts removed it should come apart. Look at the second link i posted for pics.
just checked and wrong about the pics!! :headvswal
its the link thats no longer working that had the better pics lol. :slap:
heres a pic of tc
This shows the position of the bolts but the bolts are rear facing in respect of car.
fairplay bud^^ you could of just gone to his house and done it for him ;) hehe
i know and i've missed half of MAD MAX II
cool thanks mate i will give it ago i spose sounds dodgy as f**k but here goes i only have about just under an inch to get in :confused: :headvswal :eek:
PUSH HARDER LIKE A SQUARE PEG IN A ROUND HOLE! :rofl: ;)
Small 3/8" ratchet and 14mm socket ideally get someone to hold a bar and 27mm socket on the crank sprocket and lock it off so engine does not rotate, or multi task with bar and ratchet and turn at all 4 points until each bolt is removed
hi there can you get to them if i took the starter off the side of the box or does it have to be thru the gap in the box at the bottom after engine is lifted slightly thanks lee i have a gap at the bottom of the box but its the top that is stuck lee :hyper:
