which one??
Changed spark plugs today... Went for a drive and one cylinder is not fireing.. Checked with datascan and it seems cylinder 2 is the one.. Anyone happen to know where cylinder 2 is located?? (Car is a left hand drive if that has anything to say)
Yep, I think thats right as well. Easy way to check is to pull the coil pack connector on each one in turn. When you take the connector off you will hear the engine note change as it loses that cylinder. If the engine note doesn't change then thats the one.
