Hi, wonder if anyone can help me? Been having a strange problem lately ever since upgrading my 1.0mm boost jets to 0.8 ones... My Z is running hybrid Turbo's based on HKS 2530's so gives more airflow at 9psi than stock turbo's would and also running and Andy P stage 2 chip on stock injectors with a Blitz SUS airfilter...
The problem i'm getting is a bit intermittent.. When I bury my foot in the carpet, the boost rises on my aftermarket guage to 1Bar and sometime the whole car will just cut out a bit like a fuel cut type scenario.. I've also tried nailing it also from 4000Rpm thinking it might of been a det sensor problem but it will still sometimes cut out... I'm not getting det by the way but just tried this as another check...
Has my aftermarket chip got a fuel cut safety feature we're if it detects too much boost it cuts out and if so we're can I get one that will eliminate this problem..
Just to add when the Z does cut out you can still drive normally again without any problems! Guess what i'm asking is I wanna chip that will let me run with the 0.8mm jets without cutting out! Or if you guys have also has this problem whats the solution to correct it without going back to the 1.0mm jets?? Could it also maybe an airfilter problem through the vented nose panel???
Any help would be much appreciated!!! Thanks guys!
