In memory of Mandy
not bling but look nice
got rid of the maf and now replaced with some dual airfilters which look well made and cost less than 1 airfilter from apexi
What did you do instead of the MAF mate?
what he says ^^^^^^^^^^^^^^^^^^^^^^^
This owt to do with it?
ahh well spotted. not too sure how it does it tho if anyone knows?
It is an aftermarket engine management with a pressure sensor in the manifold.
Im sure Ive read he has the AEM standalone ECU, so does away with the MAFs and you use a map sensor ( i think ).
Barry
I agree they do look nice but it's a shame they are hidden under the front panel (can't remember what it's called :confused: ). Has anyone ever thought of making one out of clear plastic? A bit blingey I suppose but at least it would show off the induction bling.
Barry
Thanks guys. Thats answered that question for me :)
yup you got it guys, full AEM with dual wideband and the airfilters cost me...................40quid for the pair and they look mint as you said its a shame u can't see em
richard
now heres a tricky answer my mate jaypsc ordered em about 15 quid a pair, but il have to check his lappy for info next time i go down to swindon, he told when he was alive but i've forgotten sorry
rich
Where did you get the pipe bends from?
rich
No worries bud, I have some from a local plumbing shop, just was interested :)
rich
They are 110 degree bends. If you can find a stainless steel supplier they will either have these on the shelf or can mandrel bend one for you. Is not too expensive depending on the grade of S/S. The internal diamet will need to be 76mm (or 3" for the "imperial" boys ...) I can supply the silicone couplers and clips if they are needed.
Dan
