Help! Brake Upgrade?
I really want to fit these monster brakes to my zed.
I know they will not just bolt on. But does anyone know what would be required to make them fit?
Has anyone done anything quite like this before?
Really you have to have all the dimensions for us to tell you, but the reality is they look like nothing I have seen and with all the engineering that would need doing it would probably be just as cheap to buy k sport 6 pots, in the first place!
They are 365mm 8 pots from a 2004 RS6!!!
They are going quite cheap at the moment and I would love to fit them.
Can anyone help?
Are the hubs the same size for disc fitment, is the disc the same PCD ? Offset could be an issue.
Fitting the calipers is a case of fabricating up suitable brackets, as long as the offset is'nt too far off.
I bought some massive Brembo Calipers last year from a Rangerover Sport, gave up in the end as the discs cost ~ £450+ each including hubs. Thats before brackets were thought of, too many variables to consider so I let it go. just a thought m8 before you buy.
mate. yes you could get tehm on, but I bet youl be needing new rims as well.
personaly dont even wast your money
I thought there would be too many issues.
This setup is currently going for just over £400 on ebay, being sold by a member of zclub if anyone's interested.
I knew it would need some fabrication to fit but it sounds like a nightmare. I would definitely need some bigger rims too.
Thanks for the help...
