while rebuilding/refitting the engine.
what are all the lil bits people remove/bypass while refitting a engine?
i mean things like egr removal and the pcv re-route thingy.
Also are there guides for them?
I do not know about a PCV re route, you are probably thinking about a 'top end bypass'. If you do a search on this forum for EGR and Top end bypass, you should come up with links to tech papers refering to them.
I removed egr, aiv, carbon canister, air con and rad, recirc valves, hicas and did a plenium water bypass
